Hello from Greece, try the version vmix trial .No know if the SD version serves my needs? I use four web cameras and about 30 photos and 10 videos each time i stream broadcast in the internet. The other version is for our economic very expensive. Is there another solution? Thank you.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ apell Welcome to the vMix forum. The Trial version is "full featured" and will give you a good idea of what vMix is capable of. If you think the SD version might be sufficient for your needs, you can test by limiting all your inputs to 768x576 or less and adjust your output settings accordingly and see if you are happy with the results. I could be wrong, but I believe that is the only limitation vMixSD imposes compared to vMixHD, namely, the allowable resolution of inputs and outputs. The Trial version will likely down scale higher resolution inputs for you so don't be fooled by that, the SD version will most likely not allow you to 'Input' them if they exceed 768x576. http://www.vmixhd.com/purchase.aspxAlternatively, you could start with the 'Basic' free version (which is SD resolution) and ascertain from there if you need access to more features, which based on your description above, you do, but it will give you an idea of what cameras, photos and videos work with vMixSD. Hope that helps. Ice
OK Thank you for your response. What interests me is to do mixing 4 cameras and mix a play list to 50 photographs and 20 to 30 videos.And Multi View cameras. Has possibility the SD version? Υου heave tried one like this, softwear, which have the characteristics of Vmix. (Sorry but I'm journalism student and i search a low cost softwear). Thank you Apell
@ apell
You have 60 days to test for free with the full version. As stated, vMix SD does everything vMix HD does, just not with HD inputs or output. The Basic version will not do what you describe since it has limited inputs. The best advice I can give is to TEST for the next 60 days. I started with vMix SD and was very pleased with it.
OK thank you very much. It is valuable your contribution. Another information please, there a free or low cost Live stream for 25 50 viewers at the same time? Αgain thank you, to have you a good night. Apell Greece
