Hello vmix team.
I have tried to contact you trou email 3 times, with no response, so I will try to contact you here now.
I have been using SD capture card with your free software version for my NGO streams for European union youth programms. Right not we are upgrading our system after 1.5 years of using the method described above. I have bought additional camera and a black magic capture cards, so I wish to start streaming 720, preferably 1080. The problem is that i have used my trial period, and now I cant set up and test the system with the new hardware, so I cant be sure that its all compatible.
Can you please extend me some sort of trial period to do so?
I really look forward for your cooperation, as we are non-profit I cant afford to invest money in things that dont work, but I will gladly buy licence if your software will be compatible with my hardware. Thank you.
