jaialai
#1 Posted : Sunday, November 15, 2026 8:24:50 AM(UTC)
jaialai
I’m experiencing an issue when viewing replays on an external monitor connected to my laptop via HDMI: the motion is not smooth. I record and stream at 1080p50. I’ve set the HDMI output to 50Hz, but the playback still isn't fluid. I’ve tried a different monitor, but that didn’t solve the problem either.
I capture 4 camera feeds using an expansion chassis (Sonnet 3-slot) equipped with two cards (a Blackmagic DeckLink Duo 2 and an Elgato 4K Pro HDMI).
On this same laptop, I handle replays, record the program feed, stream to YouTube, and output a video signal to an external display.
Could the issue lie with the monitor?
What monitors do you use to ensure smooth playback for replays?
Thanks.
My laptop.
https://drive.google.com...3uFQ/view?usp=drive_link
