Instant Replay
Viewing replays using "Instant Replay."
I’m experiencing an issue when viewing replays on an external monitor connected to my laptop via HDMI: the motion is not smooth. I record and stream at 1080p50. I’ve set the HDMI output to 50Hz, but the playback still isn't fluid. I’ve tried a different monitor, but that didn’t solve the problem either. I capture 4 camera feeds using an expansion chassis (Sonnet 3-slot) equipped with two cards (a Blackmagic DeckLink Duo 2 and an Elgato 4K Pro HDMI). On this same laptop, I handle replays, record the program feed, stream to YouTube, and output a video signal to an external display. Could the issue lie with the monitor? What monitors do you use to ensure smooth playback for replays? Thanks. My laptop. https://drive.google.com...3uFQ/view?usp=drive_link
Joined: 10/20/2023(UTC) Posts: 164  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Hi, You need to set the configuration to "discrete GPU" in the BIOS or via the OMEN Gaming Hub software, as well as within the vMix settings. update GPU driver https://www.nvidia.com/en-us/drivers/The simplest approach is to add a DeckLink Mini Monitor HD card into the Sonnet enclosure and configure it as a vMix external output. https://www.blackmagicde...klink/techspecs/W-DLK-38or configure an SDI port on the DeckLink Duo 2 as a vMix external output and add a 3G-SDI to HDMI converter Swap the positions of the Windows/vMix SSD and the replay SSD inside the laptop so that the drive dedicated to replays is connected to the CPU's PCIe lanes https://www.youtube.com/watch?v=1lI-EZBxOM4Format the replay SSD before use. Also, check its health.
I Will test this one: " configure an SDI port on the DeckLink Duo 2 as a vMix external output and add a 3G-SDI to HDMI converter"
Instant Replay
