jaialai
#1 Posted : Sunday, November 15, 2026 8:24:50 AM(UTC)
jaialai
I’m experiencing an issue when viewing replays on an external monitor connected to my laptop via HDMI: the motion is not smooth. I record and stream at 1080p50. I’ve set the HDMI output to 50Hz, but the playback still isn't fluid. I’ve tried a different monitor, but that didn’t solve the problem either.
I capture 4 camera feeds using an expansion chassis (Sonnet 3-slot) equipped with two cards (a Blackmagic DeckLink Duo 2 and an Elgato 4K Pro HDMI).
On this same laptop, I handle replays, record the program feed, stream to YouTube, and output a video signal to an external display.
Could the issue lie with the monitor?
What monitors do you use to ensure smooth playback for replays?
Thanks.
My laptop.
https://drive.google.com...3uFQ/view?usp=drive_link
Kayo33
#2 Posted : Sunday, November 15, 2026 8:28:47 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
You need to set the configuration to "discrete GPU" in the BIOS or via the OMEN Gaming Hub software, as well as within the vMix settings.
update GPU driver
https://www.nvidia.com/en-us/drivers/
The simplest approach is to add a DeckLink Mini Monitor HD card into the Sonnet enclosure and configure it as a vMix external output.
https://www.blackmagicde...klink/techspecs/W-DLK-38
or configure an SDI port on the DeckLink Duo 2 as a vMix external output and add a 3G-SDI to HDMI converter
Swap the positions of the Windows/vMix SSD and the replay SSD inside the laptop so that the drive dedicated to replays is connected to the CPU's PCIe lanes
https://www.youtube.com/watch?v=1lI-EZBxOM4
Format the replay SSD before use.
Also, check its health.
jaialai
#3 Posted : Monday, November 16, 2026 2:31:13 AM(UTC)
jaialai
I Will test this one:
" configure an SDI port on the DeckLink Duo 2 as a vMix external output and add a 3G-SDI to HDMI converter"
