RossCarter
#1 Posted : Sunday, June 1, 2025 4:31:41 PM(UTC)
RossCarter
when this error occurs api stop getting new command until we click it ok
is there any way to suppress or bypass it ?vmix er
#2 Posted : Sunday, June 1, 2025 5:49:24 PM(UTC)
By writing the api command correctly
maybe show what you are intending to accomplish/do to get more help
RossCarter on 6/1/2025(UTC)
RossCarter
#3 Posted : Sunday, June 1, 2025 6:05:26 PM(UTC)
RossCarter
its not a single command
i add some items into vmix playing list
then garbage collect pre used itemms
i guess it refers to a removed object by gc
i got an external sol to close opened error window by vb.net
but i guess there is an internal sol to resolve this and app continue func .
tnx by the way
#4 Posted : Sunday, June 1, 2025 7:11:56 PM(UTC)
tnx by the way
English ?
nikosman88
#5 Posted : Saturday, June 14, 2025 4:55:27 AM(UTC)
nikosman88
Greece
Hi. The solution that work for me
You can use AutoHotkey v2 to automatically detect and close this error popup as soon as it appears — often before you even notice it.
🔧 How it works:
It runs silently in the background
Checks every 500ms for a window titled Error (the vMix error popup)
If found, it instantly closes it
Your vMix continues working and the API resumes
The script
Code:
#Requires AutoHotkey v2.0
Persistent
SetTimer(KillErrorWindow, 500)
KillErrorWindow()
    if WinExist("ahk_exe vmix64.exe ahk_class Error") or WinExist("Error")
        WinClose
How to use:
Install AutoHotkey v2 from https://www.autohotkey.com
Open Notepad, paste the code above
Save it as KillError.ahk (important: .ahk extension)
Double-click the file to launch
It will now sit in the system tray and watch for that error popup
🔁 To run it on every boot:
Press Win + R, type shell:startup, and place a shortcut to KillError.ahk there.
#6 Posted : Saturday, June 14, 2025 5:20:53 AM(UTC)
🔧 How it works:
The script
Code:
Persistent
KillErrorWindow()
        WinClose
How to use:
Thats clever ,ignoring improper programming or solvinga bug
<g> wonder why my head hurts everytime i bang it against the wall, oh yeah remove all walls: fixed
nikosman88
#7 Posted : Saturday, June 14, 2025 6:29:37 AM(UTC)
nikosman88
Greece
🔧 How it works:
The script
Code:
Persistent
KillErrorWindow()
        WinClose
How to use:
Hi Doggy. The user asks this and yes if the scenario is -->"its not a single command
i add some items into vmix playing list" seem to work . Yes i know what you say and i understand fully what you say. Sometimes yes,workarounds can be a solution
Guest (4)
