Joined: 6/1/2025(UTC) Posts: 2  Location: Sydney Thanks: 1 times
when this error occurs api stop getting new command until we click it ok is there any way to suppress or bypass it ?
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: RossCarter  when this error occurs api stop getting new command until we click it ok is there any way to suppress or bypass it ? By writing the api command correctly maybe show what you are intending to accomplish/do to get more help
its not a single command i add some items into vmix playing list then garbage collect pre used itemms i guess it refers to a removed object by gc i got an external sol to close opened error window by vb.net but i guess there is an internal sol to resolve this and app continue func . tnx by the way
Originally Posted by: RossCarter  its not a single command i add some items into vmix playing list then garbage collect pre used itemms i guess it refers to a removed object by gc i got an external sol to close opened error window by vb.net but i guess there is an internal sol to resolve this and app continue func . tnx by the way English ?
Hi. The solution that work for me You can use AutoHotkey v2 to automatically detect and close this error popup as soon as it appears — often before you even notice it. 🔧 How it works: It runs silently in the background Checks every 500ms for a window titled Error (the vMix error popup) If found, it instantly closes it Your vMix continues working and the API resumes The script Code:
#Requires AutoHotkey v2.0
Persistent
SetTimer(KillErrorWindow, 500)
KillErrorWindow()
if WinExist("ahk_exe vmix64.exe ahk_class Error") or WinExist("Error")
WinClose
How to use: Install AutoHotkey v2 from https://www.autohotkey.com Open Notepad, paste the code above Save it as KillError.ahk (important: .ahk extension) Double-click the file to launch It will now sit in the system tray and watch for that error popup 🔁 To run it on every boot: Press Win + R, type shell:startup, and place a shortcut to KillError.ahk there.
Originally Posted by: nikosman88  Hi. The solution that work for me You can use AutoHotkey v2 to automatically detect and close this error popup as soon as it appears — often before you even notice it. 🔧 How it works: It runs silently in the background Checks every 500ms for a window titled Error (the vMix error popup) If found, it instantly closes it Your vMix continues working and the API resumes The script Code:
Persistent
KillErrorWindow()
WinClose
How to use: Install AutoHotkey v2 from https://www.autohotkey.com Open Notepad, paste the code above Save it as KillError.ahk (important: .ahk extension) Double-click the file to launch It will now sit in the system tray and watch for that error popup 🔁 To run it on every boot: Press Win + R, type shell:startup, and place a shortcut to KillError.ahk there. Thats clever ,ignoring improper programming or solvinga bug <g> wonder why my head hurts everytime i bang it against the wall, oh yeah remove all walls: fixed
Originally Posted by: doggy  Originally Posted by: nikosman88  Hi. The solution that work for me You can use AutoHotkey v2 to automatically detect and close this error popup as soon as it appears — often before you even notice it. 🔧 How it works: It runs silently in the background Checks every 500ms for a window titled Error (the vMix error popup) If found, it instantly closes it Your vMix continues working and the API resumes The script Code:
Persistent
KillErrorWindow()
WinClose
How to use: Install AutoHotkey v2 from https://www.autohotkey.com Open Notepad, paste the code above Save it as KillError.ahk (important: .ahk extension) Double-click the file to launch It will now sit in the system tray and watch for that error popup 🔁 To run it on every boot: Press Win + R, type shell:startup, and place a shortcut to KillError.ahk there. Thats clever ,ignoring improper programming or solvinga bug <g> wonder why my head hurts everytime i bang it against the wall, oh yeah remove all walls: fixed Hi Doggy. The user asks this and yes if the scenario is -->"its not a single command i add some items into vmix playing list" seem to work . Yes i know what you say and i understand fully what you say. Sometimes yes,workarounds can be a solution
