Beta Discussion
Flatten Layers and merge
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Hello, when I activate the “Flatten Layers” function, the merge does not work anymore, it makes a fade like when it is not the same source, if I deactivate it, it works fine.
Joined: 1/13/2010(UTC) Posts: 5,212  Location: Gold Coast, Australia Was thanked: 4485 time(s) in 1564 post(s)
Yes, that is correct. When you Flatten Layers, you are effectively combining them into a single image, thus Merge will have no effect as the layers no longer exist as far as rendering is concerned.
I mean when that font already “Flatten Layers”, put it in another font to make a split screen,
Yes that is correct, as the flattened input is a single image now, so there is nothing to merge.
Joined: 7/4/2021(UTC) Posts: 378  Thanks: 8 times Was thanked: 55 time(s) in 46 post(s)
This isn't me requesting this, but, just asking if it would be feasible at some point in the future, since the discussion is already ongoing.
Would it--at some point in the future, not this release--be possible for the Merge transition to use some sort of image analysis rather than layer recognition?
Or is that altogether outside the potential of modern computing and/or vMix in general?
Again, not asking for it, just asking if it's even feasible.
Beta Discussion
