dark_ata
#1 Posted : Thursday, November 28, 2024 11:02:43 PM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
Hello, when I activate the “Flatten Layers” function, the merge does not work anymore, it makes a fade like when it is not the same source, if I deactivate it, it works fine.
#2 Posted : Friday, November 29, 2024 1:33:34 AM(UTC)
Was thanked: 4446 time(s) in 1556 post(s)
Yes, that is correct.
When you Flatten Layers, you are effectively combining them into a single image, thus Merge will have no effect as the layers no longer exist as far as rendering is concerned.
dark_ata
#3 Posted : Friday, November 29, 2024 2:04:02 AM(UTC)
dark_ata
I mean when that font already “Flatten Layers”, put it in another font to make a split screen,
#4 Posted : Friday, November 29, 2024 2:54:53 AM(UTC)
Yes that is correct, as the flattened input is a single image now, so there is nothing to merge.
WaltG12
#5 Posted : Friday, November 29, 2024 7:25:02 AM(UTC)
WaltG12
Was thanked: 53 time(s) in 44 post(s)
This isn't me requesting this, but, just asking if it would be feasible at some point in the future, since the discussion is already ongoing.
Would it--at some point in the future, not this release--be possible for the Merge transition to use some sort of image analysis rather than layer recognition?
Or is that altogether outside the potential of modern computing and/or vMix in general?
Again, not asking for it, just asking if it's even feasible.
