envideano
#1 Posted : Thursday, September 26, 2024 7:18:55 PM(UTC)
envideano
I'm having issues with vMix on my laptop, an Acer Nitro 5 AN515-46-R082 (AMD Ryzen 7, 16GB RAM, 512GB SSD, NVIDIA GeForce RTX 3050). When I try to activate the SRT output, the indicator does not appear on the main screen, even though the SRT is supposed to be active.
I have checked my network settings, updated all drivers, and ensured vMix is up-to-date, but the problem persists. Other streaming protocols work fine, but SRT specifically seems to have issues. Is there any known compatibility issue with AMD systems, or any specific settings I need to adjust for SRT to work on my setup?
Any help would be appreciated!
Thank you.
ckvideo
#2 Posted : Saturday, September 28, 2024 8:49:09 PM(UTC)
ckvideo
Germany
Originally Posted by: envideano Go to Quoted Post
Thank you.
running vMix on (too) small laptop screens seems to be tricky sometimes. Some UI elements are sometimes not shown. Try your setup with a bigger external monitor. To check SRT data transmission, use the statistics button (rainbow column items) in the lower right corner of the vMix app window.
Hope this helps,
Christian
