SRT
SRT Output Not working/Showing on Acer Nitro 5 with AMD Ryzen 7
I'm having issues with vMix on my laptop, an Acer Nitro 5 AN515-46-R082 (AMD Ryzen 7, 16GB RAM, 512GB SSD, NVIDIA GeForce RTX 3050). When I try to activate the SRT output, the indicator does not appear on the main screen, even though the SRT is supposed to be active.
I have checked my network settings, updated all drivers, and ensured vMix is up-to-date, but the problem persists. Other streaming protocols work fine, but SRT specifically seems to have issues. Is there any known compatibility issue with AMD systems, or any specific settings I need to adjust for SRT to work on my setup?
Any help would be appreciated!
Thank you.
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Thank you. Hi, running vMix on (too) small laptop screens seems to be tricky sometimes. Some UI elements are sometimes not shown. Try your setup with a bigger external monitor. To check SRT data transmission, use the statistics button (rainbow column items) in the lower right corner of the vMix app window. Hope this helps, Christian
SRT
