JosefinaF
#1 Posted : Wednesday, July 17, 2024 1:29:23 PM(UTC)
JosefinaF
Hi there!
I'm getting choppy audio sometimes when I add some inputs like videos, the image is fine but the audio starts to get really choppy on external mode and it stutters. Once this problem starts I have to close vmix and open it again.. the thing is that it happens during livestreaming on a tv channel and I have to close that to sort it out. I also record it and when I listen to the recording the audio is fine.
I couldn't find a solution or an explanation as to why it happens, could it be an audio or video driver on the computer that needs to be updated? Or the graphic card? Has anyone had a similar problem?
Thanks!
dmwkr
#2 Posted : Wednesday, July 17, 2024 5:50:59 PM(UTC)
dmwkr
Does "external mode" mean external output? If so, make sure that you are configuring the audio bus ONLY in the External Output Settings, and NOT in the Audio Outputs Settings as well. So, if you are sending the Master bus to external output, set the Master in Audio Output settings to "Enabled", and not your output device.
thanks 1 user thanked dmwkr for this useful post.
JosefinaF on 7/18/2024(UTC)
JosefinaF
#3 Posted : Thursday, July 18, 2024 12:25:27 AM(UTC)
JosefinaF
Hi, thanks for your answer!
Yes, sorry, I meant external output. It also happened when I tried to make a vmix call.
I'll try that, thank you!
Watty1985
#4 Posted : Monday, October 12, 2026 12:50:29 PM(UTC)
Watty1985
Since the audio sounds fine in the recording but becomes choppy through the external output, I’d check the audio routing settings first rather than assuming it’s a graphics card issue. It may be worth making sure the Master bus isn’t configured twice in the Audio Outputs and External Output settings. Hopefully that helps narrow down the cause without having to restart vMix during a live broadcast.
MarcoCTaylor
#5 Posted : Friday, October 16, 2026 7:29:06 PM(UTC)
MarcoCTaylor
Originally Posted by: JosefinaF Go to Quoted Post
Hi there!
Thanks!
Oof, that external stuttering bug is the worst! 💀 If the local recording sounds clean, the issue is def happening post-mix, likely with how your PC handles the audio buffer for the external feed. Keeping a live TV feed from crashing requires the same insane reflexes as dodging spikes in geometry dash fr 😂. I'd highly recommend checking your ASIO drivers and tweaking the audio buffer size in your vMix settings, that usually patches things right up. Good luck!
Similar Topics
Choppy audio on external output (General Discussion)
by JosefinaF 1/20/2025 10:12:36 AM(UTC)
Choppy audio on SDI out (Hardware Compatibility)
by MattGrover 7/28/2020 7:38:56 PM(UTC)
Choppy Audio via Decklink Duo 2 only in vMix (General Discussion)
by NiBTour 7/13/2019 4:02:23 AM(UTC)
Choppy audio and video on VMIXCALL (vMix Call)
by michaelrb 3/14/2018 3:31:14 PM(UTC)
Choppy audio when using external. (General Discussion)
by RandomStreamer 7/10/2017 10:54:37 PM(UTC)
Choppy Audio on recording (General Discussion)
by Greg 5/10/2012 3:35:25 PM(UTC)
