GT
Gt title text &image moving show sponsor
Joined: 11/11/2022(UTC) Posts: 4  Location: johor Thanks: 1 times
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: weiloon1010  Don't even dream it ! While the effect might be simulated with images or a simple rectangle and a lot of fiddeling around with timing and dupkicates of the elements , combining it with the information fields needed it becomes sheer impossible and a real PITA to get it right not to mantion adding the same data to duplicate fields etc etc . If you really want something like this look for something externally that can create animations that has timelines for them , proper grouping of elements and so forth. One would have better luck with the by now for vMix depricated XAMLL animation titles
Thx for the reply🫡🫡 Have any recommend 3rd party software to do that ?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
This should be possible if you split your scoreboard into a left and a right part (two title inputs). Add two transparent colour inputs, place sponsor logo on layer 1, left and right part on layers 2 and 3, with the different position. Use mix input as an overlay and to merge between these transparent inputs.
 1 user thanked dmwkr for this useful post.
For the score , clock, 24sec , quarter is data changing
Still thinking how to fly or expand A to B point Even I mask a layer , the text will appear fr 1st character to last Instead of full text together moving
You have to prepare your scoreboard, that it can be split into two pieces, thus two inputs. Are you familiar with mix inputs and how merge works? Here is the idea: https://imgur.com/a/ZlM3oce
GT
