weiloon1010
#1 Posted : Tuesday, July 2, 2024 9:37:48 AM(UTC)
weiloon1010
Malaysia
hi everyone , can share some idea how to do this moving scoreboard to show the sponsor
Name score time quarter together moving left right
And move back
a point to b point
https://drive.google.com...EVfNFA/view?usp=drivesdk
#2 Posted : Wednesday, July 3, 2024 3:08:22 AM(UTC)
And move back
a point to b point
Don't even dream it !
While the effect might be simulated with images or a simple rectangle and a lot of fiddeling around with timing and dupkicates of the elements , combining it with the information fields needed it becomes sheer impossible and a real PITA to get it right not to mantion adding the same data to duplicate fields etc etc .
If you really want something like this look for something externally that can create animations that has timelines for them , proper grouping of elements and so forth.
One would have better luck with the by now for vMix depricated XAMLL animation titles
weiloon1010
#3 Posted : Friday, July 12, 2024 6:53:10 PM(UTC)
weiloon1010
Malaysia
Thx for the reply🫡🫡
Have any recommend 3rd party software to do that ?
dmwkr
#4 Posted : Friday, July 12, 2024 8:19:37 PM(UTC)
dmwkr
This should be possible if you split your scoreboard into a left and a right part (two title inputs). Add two transparent colour inputs, place sponsor logo on layer 1, left and right part on layers 2 and 3, with the different position. Use mix input as an overlay and to merge between these transparent inputs.
thanks 1 user thanked dmwkr for this useful post.
weiloon1010 on 7/12/2024(UTC)
weiloon1010
#5 Posted : Friday, July 12, 2024 11:07:24 PM(UTC)
weiloon1010
Malaysia
For the score , clock, 24sec , quarter is data changing
Still thinking how to fly or expand A to B point
Even I mask a layer , the text will appear fr 1st character to last
Instead of full text together moving
dmwkr
#6 Posted : Saturday, July 13, 2024 12:03:06 AM(UTC)
dmwkr
You have to prepare your scoreboard, that it can be split into two pieces, thus two inputs. Are you familiar with mix inputs and how merge works?
Here is the idea:
https://imgur.com/a/ZlM3oce
Chircanu on 7/13/2024(UTC)
weiloon1010
#7 Posted : Saturday, July 13, 2024 3:21:13 AM(UTC)
weiloon1010
Malaysia
Thx dmwkr idea 💡 🫡👍
