PFBM
#1 Posted : Wednesday, December 17, 2014 6:21:44 PM(UTC)
PFBM
Was thanked: 36 time(s) in 31 post(s)
HI !
MXF recording on vMix 15 !
Material eXchange Format (MXF) is a container format for professional digital video and audio media defined by a set of SMPTE standards.
can it be done ?
multi audio channels on multicorder camera+vmix audio for example.
http://en.wikipedia.org/...Material_Exchange_Format
Best regards,
PFBM
thomas
#2 Posted : Wednesday, December 17, 2014 7:40:07 PM(UTC)
thomas
+1 - we recently installed vMix in our broadcast station and used a lot of it`s features on a national broadcast, worked like a charm! It would be hugely appreciated if MXF-recording could be implemented, as our storage and workflow uses MXF. Don`t remember what codec we use within mxf. But can check and report back.
PFBM wrote:
HI !
can it be done ?
Best regards,
PFBM
thanks 1 user thanked thomas for this useful post.
PFBM on 12/17/2014(UTC)
PFBM
#3 Posted : Wednesday, December 17, 2014 7:43:37 PM(UTC)
PFBM
Lets do the MXF petition to Martin :)
Cheers,
PFBM
richardgatarski
#4 Posted : Thursday, December 18, 2014 4:55:54 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
+0,5 (interested, but no immediate demand)
I am under the impression that many European broadcasters work with MXF containers. One of our customer's require for HD:
MXF OP1a XDCAMHD with 8 channel audio. All media are to be delivered as High definition 1920x1080 50i interlaced video
compressed with MPEG2 4:2:2 compression at 50 Mbps (4:2:2Profile@ HighLevel), and 8 channels of uncompressed 24 bit audio at 48kHz.
Most likely our recordings require some basic editing before delivery. For example cutting off leading and trailing material before the actual program. I guess this can be done in video editors that support "smart rendering", and thus reduce the rendering time.
PFBM on 12/18/2014(UTC)
jmpaoli
#5 Posted : Thursday, December 18, 2014 6:38:36 AM(UTC)
jmpaoli
+1 needed with plenty of broadcast channel
thanks 1 user thanked jmpaoli for this useful post.
Ittaidv
#6 Posted : Thursday, December 18, 2014 4:42:25 PM(UTC)
Ittaidv
PFBM wrote:
HI !
can it be done ?
Best regards,
PFBM
+1, but i would prefer the other codecs to have more options first, especially audio whise.
thanks 1 user thanked Ittaidv for this useful post.
rrpro on 12/18/2014(UTC)
rrpro
#7 Posted : Thursday, December 18, 2014 6:44:03 PM(UTC)
rrpro
+1
(and add more settings to the current formats)
