Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
HI ! MXF recording on vMix 15 ! Material eXchange Format (MXF) is a container format for professional digital video and audio media defined by a set of SMPTE standards. can it be done ? multi audio channels on multicorder camera+vmix audio for example. http://en.wikipedia.org/...Material_Exchange_FormatBest regards, PFBM
Thanks: 17 times Was thanked: 5 time(s) in 4 post(s)
+1 - we recently installed vMix in our broadcast station and used a lot of it`s features on a national broadcast, worked like a charm! It would be hugely appreciated if MXF-recording could be implemented, as our storage and workflow uses MXF. Don`t remember what codec we use within mxf. But can check and report back. PFBM wrote:HI ! MXF recording on vMix 15 ! Material eXchange Format (MXF) is a container format for professional digital video and audio media defined by a set of SMPTE standards. can it be done ? multi audio channels on multicorder camera+vmix audio for example. http://en.wikipedia.org/...Material_Exchange_FormatBest regards, PFBM
 1 user thanked thomas for this useful post.
Lets do the MXF petition to Martin :)
Cheers,
PFBM
Rank:: Advanced Member
+0,5 (interested, but no immediate demand)
I am under the impression that many European broadcasters work with MXF containers. One of our customer's require for HD:
MXF OP1a XDCAMHD with 8 channel audio. All media are to be delivered as High definition 1920x1080 50i interlaced video compressed with MPEG2 4:2:2 compression at 50 Mbps (4:2:2Profile@ HighLevel), and 8 channels of uncompressed 24 bit audio at 48kHz.
Most likely our recordings require some basic editing before delivery. For example cutting off leading and trailing material before the actual program. I guess this can be done in video editors that support "smart rendering", and thus reduce the rendering time.
 1 user thanked richardgatarski for this useful post.
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
+1 needed with plenty of broadcast channel
 1 user thanked jmpaoli for this useful post.
PFBM wrote:HI ! MXF recording on vMix 15 ! Material eXchange Format (MXF) is a container format for professional digital video and audio media defined by a set of SMPTE standards. can it be done ? multi audio channels on multicorder camera+vmix audio for example. http://en.wikipedia.org/...Material_Exchange_FormatBest regards, PFBM +1, but i would prefer the other codecs to have more options first, especially audio whise.
 1 user thanked Ittaidv for this useful post.
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
+1
(and add more settings to the current formats)
