h2video.nl
#1 Posted : Sunday, May 14, 2023 6:39:02 PM(UTC)
h2video.nl
When I input a camera with audio I can choose to split the audio - L + R.
This is then downmixed with other inputs etc to a double mono output (L+R combined).
Is there a way to split the output audio in a similar way and have the audiolevels seperate?
This would alow me to control and record L+R on a different / individual level, like normal and safely level (reduced).
In postprocessing this would alow for using one of these channels or switch of a level is clipped.
In a livestream this could still be combined or the levels would just be a little bit off (but you can control that).
cheers Stefan
zenvideo
#2 Posted: : Sunday, May 14, 2023 11:55:30 PM(UTC)
zenvideo
Maybe find a VST3 plugin to add to the Master output which allows you to control L & R gain independently?
