Rank:: Advanced Member
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
When I input a camera with audio I can choose to split the audio - L + R.
This is then downmixed with other inputs etc to a double mono output (L+R combined).
Is there a way to split the output audio in a similar way and have the audiolevels seperate? This would alow me to control and record L+R on a different / individual level, like normal and safely level (reduced).
In postprocessing this would alow for using one of these channels or switch of a level is clipped.
In a livestream this could still be combined or the levels would just be a little bit off (but you can control that).
cheers Stefan
Maybe find a VST3 plugin to add to the Master output which allows you to control L & R gain independently?
