apell
#1 Posted : Tuesday, April 18, 2023 12:00:57 AM(UTC)
apell
Hi, how do i have higer definition in the image on vmix edition standard?
Thank you Apostolos Greece.
nikosman88
#2 Posted : Tuesday, April 18, 2023 3:58:22 AM(UTC)
nikosman88
Greece
Hello. Maximum resolution for vmix hd is 1920*1080. If you want higher you have to buy vmix 4k or pro
apell
#3 Posted : Friday, April 21, 2023 6:20:14 AM(UTC)
apell
It is not...
the selected resolution is not supported in this edition of vmix.Upgrade vmix to eneble more features.....
nikosman88
#4 Posted : Friday, April 21, 2023 7:08:03 AM(UTC)
nikosman88
Greece
Yes you`re right. I thought you use vmix Basic HD that costs 60$ but you use the free vmix basic version. So no you cant use higher definition. You have to give 60$ plus 24% VAT we have in Greece, it means about 68€ in order to be able to work HD.
apell
#5 Posted : Saturday, April 22, 2023 4:12:59 AM(UTC)
apell
Thanks for the reply, I have purchased the version HD (180 euros) from 5 years ago.
I use 4 web cams Logitech C270 HD.
Thank you from Greece
Apostolos
nikosman88
#6 Posted : Sunday, April 23, 2023 6:47:46 AM(UTC)
nikosman88
Greece
Apostolos
So You have to use the 5 years before version or buy again HD
