higer definition in vmix stanterd
Hi, how do i have higer definition in the image on vmix edition standard? Thank you Apostolos Greece.
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 97 time(s) in 93 post(s)
Hello. Maximum resolution for vmix hd is 1920*1080. If you want higher you have to buy vmix 4k or pro
It is not...
the selected resolution is not supported in this edition of vmix.Upgrade vmix to eneble more features.....
Yes you`re right. I thought you use vmix Basic HD that costs 60$ but you use the free vmix basic version. So no you cant use higher definition. You have to give 60$ plus 24% VAT we have in Greece, it means about 68€ in order to be able to work HD.
Thanks for the reply, I have purchased the version HD (180 euros) from 5 years ago. I use 4 web cams Logitech C270 HD. Thank you from Greece Apostolos
Originally Posted by: apell  Thanks for the reply, I have purchased the version HD (180 euros) from 5 years ago. I use 4 web cams Logitech C270 HD. Thank you from Greece Apostolos So You have to use the 5 years before version or buy again HD
