	higer definition in vmix stanterd
                Hi, how do i have higer definition in the image on vmix edition standard?Thank you Apostolos Greece.
 Joined: 12/24/2021(UTC) Posts: 733  Location: athensThanks: 166 timesWas thanked: 96 time(s) in 92 post(s)
                Hello. Maximum resolution for vmix hd is 1920*1080. If you want higher you have to buy vmix 4k or pro |
                It is not...
 the selected resolution is not supported in this edition of vmix.Upgrade vmix to eneble more features.....
                Yes you`re right. I thought you use vmix Basic HD that costs 60$ but you use the free vmix basic version. So no you cant use higher definition. You have to give 60$ plus 24% VAT we have in Greece, it means about 68€ in order to be able to work HD. |
                Thanks for the reply, I have purchased the version HD (180 euros) from 5 years ago.I use 4 web cams Logitech C270 HD.
 Thank you from Greece
 Apostolos
                Originally Posted by: apell  Thanks for the reply, I have purchased the version HD (180 euros) from 5 years ago.I use 4 web cams Logitech C270 HD.
 Apostolos
 So You have to use the 5 years before version or buy again HD |
