narcus
#1 Posted : Monday, March 27, 2023 7:51:10 PM(UTC)
narcus
Austria
What I would like to do:
I have a playlist with 3 clips
I manually trigger playing of clip 1 with my streamdeck. Auto next is disabled in vMix. Clip 1 is selected
How can I then automatically preselect clip 2 without having to double click clip 2
I only want to press play on my streamdeck again for the next clip to play
#2 Posted : Monday, March 27, 2023 8:23:01 PM(UTC)
use NextPlayListEntry
nikosman88
#3 Posted : Monday, March 27, 2023 11:26:01 PM(UTC)
nikosman88
Greece
I think he means list as playlist,so this shortcut cant be use in this ocassion
narcus
#4 Posted : Tuesday, March 28, 2023 1:20:41 AM(UTC)
narcus
Austria
Thank you for your quick suggestion. I am actually talking about “List” and not “Playlist” and I usually have 20 files there and that's why I use the list because from my understanding if I add 20 video files to vmix it's like adding 20 Cameras
#5 Posted : Tuesday, March 28, 2023 2:12:23 AM(UTC)
Wel he did write playlist and both list and playlist are specific (different) vMix items . Apples and Peares
#6 Posted : Tuesday, March 28, 2023 2:33:36 AM(UTC)
3 versus 20 LOL
Like adding 20 video inputs ;-)
What about "NextItem" (and play) ?
narcus
#7 Posted : Tuesday, March 28, 2023 3:21:24 AM(UTC)
narcus
Austria
“NextItem” brings me very close to a solution but not quite. NextItem selects the next item so it becomes “bold” and if on program it plays that item. if the playlist is on preview the next item also becomes “bold” but the orange bar does not move down to the next. If I then press “play out” it starts from the first clip in the list which I don't want
#8 Posted : Tuesday, March 28, 2023 3:38:27 AM(UTC)
As mentioned NextItem and play (= 2 shortcuts under same key) (not playout). Use a transition between having the list in preview or output
WHo cares about the orange if the correct ( next -> bold) video is playing ?
ANd please use the correct name: playlist <> list . they are 2 different vMix enteties ! its one or the other ( one is made up from inputs allready loaded the other of items strait from a disk)
narcus on 3/28/2023(UTC)
narcus
#9 Posted : Tuesday, March 28, 2023 3:49:27 AM(UTC)
narcus
Austria
thank you that solved my problem!
Similar Topics
List issues (General Discussion)
by Lwells 10/2/2026 10:11:16 AM(UTC)
Zoom Participant Source List Limit (General Discussion)
by greggibson 9/18/2026 5:11:03 AM(UTC)
Multichannel Audio in Lists (Feature Requests)
by Riotline 9/17/2026 12:15:41 PM(UTC)
Fade on playlist and layers & Sys info input for multiview (Feature Requests)
by emet 8/3/2026 8:42:43 PM(UTC)
Playlist Issue (General Discussion)
by buntonn 7/2/2026 4:59:40 PM(UTC)
List Triggers (General Discussion)
by buntonn 6/17/2026 8:59:30 PM(UTC)
Playlist Export/Import buttons (Feature Requests)
by DAScott 5/28/2026 5:21:06 AM(UTC)
Request: API Total Time Remaining in VideoList (Feature Requests)
by ChrisHoS 4/25/2026 5:01:15 AM(UTC)
srt listener mode (General Discussion)
by artyomchebko 3/4/2026 12:59:05 AM(UTC)
In the "list" visual control of the videos. (Feature Requests)
by Alain Lahaye 2/26/2026 7:47:35 PM(UTC)
is there any option to send playlist to preview ? (General Discussion)
by vighneshacharya 1/30/2026 10:56:14 PM(UTC)
Triggers for specific index in List input (Feature Requests)
by orwinetkins 1/24/2026 5:18:04 AM(UTC)
Confirming: Does using a list save vMix overhead? (General Discussion)
Belarus knbPixels 12/11/2025 6:12:18 AM(UTC)
Lock List Option (Feature Requests)
by yankee 12/8/2025 11:03:27 PM(UTC)
Remove item from List input doesn't actually remove it (General Discussion)
by john-at-heretorecord 11/8/2025 12:12:35 AM(UTC)
List of hard coded or untranslatable strings in vMix (Language Translations)
by robertskiba 11/4/2025 10:20:47 PM(UTC)
List Management (General Discussion)
by AudioGreg 11/4/2025 10:21:38 AM(UTC)
IP to Whitelist for licensing (General Discussion)
by james hathcock 10/10/2025 6:25:51 AM(UTC)
List input duration and remaining/position in API xml file (Feature Requests)
by Olesk 8/22/2025 6:25:23 AM(UTC)
list input search (Beta Discussion)
by nikosman88 8/17/2025 2:09:53 AM(UTC)
Playlist remaining time (Feature Requests)
by issei 8/3/2025 11:57:32 AM(UTC)
Playout PlayList on OUT 2 to 4 (Feature Requests)
by MrB. 7/22/2025 8:13:11 PM(UTC)
Help with List, Playlists for a lot of Commercials & Graphics (General Discussion)
by Tim P. 7/21/2025 12:37:39 PM(UTC)
Select value from list widget, then use to set selected row in Excel (GT)
by jaxon 7/19/2025 1:53:13 AM(UTC)
UTC: Passing Multiple Data Values from List Widget to Title Fields (GT)
by jaxon 6/6/2025 11:54:07 PM(UTC)
Playlist: How to show Time elapsed/remaining for live inputs with a duration like videos? (General Discussion)
by sky1 5/21/2025 5:31:14 AM(UTC)
Open more then one "List window" (Feature Requests)
by Zahi 5/5/2025 6:17:39 PM(UTC)
Display input name under the 'Fullscreen' pick list (Feature Requests)
by davidelsbury 5/4/2025 7:40:48 AM(UTC)
List input-On playback time trigger per item (Feature Requests)
by nikosman88 4/19/2025 3:09:17 AM(UTC)
Playlist - Sequence of live camera shots (General Discussion)
by frankb3 4/1/2025 10:06:50 PM(UTC)
