Joined: 10/20/2017(UTC) Posts: 23  Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
What I would like to do: I have a playlist with 3 clips I manually trigger playing of clip 1 with my streamdeck. Auto next is disabled in vMix. Clip 1 is selected How can I then automatically preselect clip 2 without having to double click clip 2 I only want to press play on my streamdeck again for the next clip to play
Originally Posted by: narcus  What I would like to do: I have a playlist with 3 clips I manually trigger playing of clip 1 with my streamdeck. Auto next is disabled in vMix. Clip 1 is selected How can I then automatically preselect clip 2 without having to double click clip 2 I only want to press play on my streamdeck again for the next clip to play
use NextPlayListEntry
Originally Posted by: doggy  Originally Posted by: narcus  What I would like to do: I have a playlist with 3 clips I manually trigger playing of clip 1 with my streamdeck. Auto next is disabled in vMix. Clip 1 is selected How can I then automatically preselect clip 2 without having to double click clip 2 I only want to press play on my streamdeck again for the next clip to play
use NextPlayListEntry I think he means list as playlist,so this shortcut cant be use in this ocassion
Thank you for your quick suggestion. I am actually talking about “List” and not “Playlist” and I usually have 20 files there and that's why I use the list because from my understanding if I add 20 video files to vmix it's like adding 20 Cameras
Originally Posted by: nikosman88  Originally Posted by: doggy  Originally Posted by: narcus  What I would like to do: I have a playlist with 3 clips I manually trigger playing of clip 1 with my streamdeck. Auto next is disabled in vMix. Clip 1 is selected How can I then automatically preselect clip 2 without having to double click clip 2 I only want to press play on my streamdeck again for the next clip to play
use NextPlayListEntry I think he means list as playlist,so this shortcut cant be use in this ocassion Wel he did write playlist and both list and playlist are specific (different) vMix items . Apples and Peares
Originally Posted by: narcus  Thank you for your quick suggestion. I am actually talking about “List” and not “Playlist” and I usually have 20 files there and that's why I use the list because from my understanding if I add 20 video files to vmix it's like adding 20 Cameras 3 versus 20 LOL Like adding 20 video inputs ;-) What about "NextItem" (and play) ?
“NextItem” brings me very close to a solution but not quite. NextItem selects the next item so it becomes “bold” and if on program it plays that item. if the playlist is on preview the next item also becomes “bold” but the orange bar does not move down to the next. If I then press “play out” it starts from the first clip in the list which I don't want
Originally Posted by: narcus  “NextItem” brings me very close to a solution but not quite. NextItem selects the next item so it becomes “bold” and if on program it plays that item. if the playlist is on preview the next item also becomes “bold” but the orange bar does not move down to the next. If I then press “play out” it starts from the first clip in the list which I don't want As mentioned NextItem and play (= 2 shortcuts under same key) (not playout). Use a transition between having the list in preview or output WHo cares about the orange if the correct ( next -> bold) video is playing ? ANd please use the correct name: playlist <> list . they are 2 different vMix enteties ! its one or the other ( one is made up from inputs allready loaded the other of items strait from a disk)
thank you that solved my problem!
