omfgblondie
#1 Posted : Thursday, March 16, 2023 7:30:42 PM(UTC)
omfgblondie
Hello!
I've got an asset that I set up in GT Title Designer. It consists of many small images that I will change during the production. I've got a nice ZoomFade animation set up for the DataChange, and that works fine.
What would really make the production pop is if I could make a sound effect play when that DataChange happens. I thought I could maybe use the Image Sequence trick, so I made a sound effect and placed it in the same folder with the same name, and then on the second layer of DataChangeIn and DataChangeOut I added a ImageSequence animation. This did not work. I also tried making a 2 frame image sequence, just to see that it was a single frame issue.
Is what I'm trying to achieve even possible?
I'm still on VMIX 24 as our license to upgrade has run out. If this is possible in future iterations, I can put in the request for an immediate upgrade.
#2 Posted : Thursday, March 16, 2023 9:00:52 PM(UTC)
Originally Posted by: omfgblondie Go to Quoted Post
Hello!
One could use a script that checks on changed data/content in the title and call a function like play an audio file or so
omfgblondie
#3 Posted : Wednesday, March 22, 2023 9:48:22 PM(UTC)
omfgblondie
Thanks for these responses. The methods described are seemingly not available in Vmix 24, so I'll put in a request for an upgrade with our procurement department.
dmwkr
#4 Posted : Wednesday, March 22, 2023 10:10:50 PM(UTC)
dmwkr
I'm pretty sure, that these responses are coming from bots, and that's actually kind of scary. These methods are not available in vMix 26.
#5 Posted : Wednesday, March 22, 2023 11:32:11 PM(UTC)
exactly, hence asked for illustrations ;-)
omfgblondie
#6 Posted : Thursday, March 23, 2023 12:38:29 AM(UTC)
omfgblondie
Fortunately the upgrade isn't very expensive, because I'd already submitted it. And it'll be good to have. Strange that someone would make bots that give detailed false information on the VMIX forums
#7 Posted : Thursday, March 23, 2023 1:30:20 AM(UTC)
sadly yes , instead of answering with valid solutions one will first have to check now if a response is ligit also
Glad to see admin reacted to these answers being reported and has deleted those responses confirming they were BS
A way to have a sound is to use a script to check in the title if a text content has changed and play an audio file or audio input is the most flexible way
omfgblondie
#8 Posted : Thursday, March 23, 2023 1:35:38 AM(UTC)
omfgblondie
Unfortunately scripting is a bit over my head, so I'll go without. It's not mission critical, just a nice to have.
