Sound playing on DataChange
Joined: 5/11/2021(UTC) Posts: 5  Location: Horsham Thanks: 1 times
Hello!
I've got an asset that I set up in GT Title Designer. It consists of many small images that I will change during the production. I've got a nice ZoomFade animation set up for the DataChange, and that works fine.
What would really make the production pop is if I could make a sound effect play when that DataChange happens. I thought I could maybe use the Image Sequence trick, so I made a sound effect and placed it in the same folder with the same name, and then on the second layer of DataChangeIn and DataChangeOut I added a ImageSequence animation. This did not work. I also tried making a 2 frame image sequence, just to see that it was a single frame issue.
Is what I'm trying to achieve even possible?
I'm still on VMIX 24 as our license to upgrade has run out. If this is possible in future iterations, I can put in the request for an immediate upgrade.
I'm still on VMIX 24 as our license to upgrade has run out. If this is possible in future iterations, I can put in the request for an immediate upgrade. One could use a script that checks on changed data/content in the title and call a function like play an audio file or so
Thanks for these responses. The methods described are seemingly not available in Vmix 24, so I'll put in a request for an upgrade with our procurement department.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: omfgblondie  Thanks for these responses. The methods described are seemingly not available in Vmix 24, so I'll put in a request for an upgrade with our procurement department. I'm pretty sure, that these responses are coming from bots, and that's actually kind of scary. These methods are not available in vMix 26.
Originally Posted by: dmwkr  Originally Posted by: omfgblondie  Thanks for these responses. The methods described are seemingly not available in Vmix 24, so I'll put in a request for an upgrade with our procurement department. I'm pretty sure, that these responses are coming from bots, and that's actually kind of scary. These methods are not available in vMix 26. exactly, hence asked for illustrations ;-)
Fortunately the upgrade isn't very expensive, because I'd already submitted it. And it'll be good to have. Strange that someone would make bots that give detailed false information on the VMIX forums
Originally Posted by: omfgblondie  Fortunately the upgrade isn't very expensive, because I'd already submitted it. And it'll be good to have. Strange that someone would make bots that give detailed false information on the VMIX forums sadly yes , instead of answering with valid solutions one will first have to check now if a response is ligit also Glad to see admin reacted to these answers being reported and has deleted those responses confirming they were BS A way to have a sound is to use a script to check in the title if a text content has changed and play an audio file or audio input is the most flexible way
Originally Posted by: doggy  Originally Posted by: omfgblondie  Fortunately the upgrade isn't very expensive, because I'd already submitted it. And it'll be good to have. Strange that someone would make bots that give detailed false information on the VMIX forums sadly yes , instead of answering with valid solutions one will first have to check now if a response is ligit also Glad to see admin reacted to these answers being reported and has deleted those responses confirming they were BS A way to have a sound is to use a script to check in the title if a text content has changed and play an audio file or audio input Unfortunately scripting is a bit over my head, so I'll go without. It's not mission critical, just a nice to have.
