richk
#1 Posted : Saturday, January 14, 2023 7:34:01 AM(UTC)
richk
Is it possible to import a playlist from XML? of for that matter any other type of data file?
#2 Posted : Saturday, January 14, 2023 9:06:24 AM(UTC)
AFAIK No. Playlist is populated by the available inputs allready in your setup , PlayLists are linked to the currently active Preset in vMix (see documentation, worth a read)
Lists can be populated by external means for example an M3U file (Again see documantation) . Due to the presence of some shortcuts files can be added so if for example you have a source of files within an XML a script could extract their reference and add to the list
richk on 1/15/2023(UTC)
Guest (4)
