Joined: 1/14/2023(UTC) Posts: 1  Location: Westfield Thanks: 1 times
Is it possible to import a playlist from XML? of for that matter any other type of data file?
Joined: 12/27/2012(UTC) Posts: 5,508  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: richk  Is it possible to import a playlist from XML? of for that matter any other type of data file? AFAIK No. Playlist is populated by the available inputs allready in your setup , PlayLists are linked to the currently active Preset in vMix (see documentation, worth a read) Lists can be populated by external means for example an M3U file (Again see documantation) . Due to the presence of some shortcuts files can be added so if for example you have a source of files within an XML a script could extract their reference and add to the list
