Joined: 1/25/2012(UTC) Posts: 17 Location: Berwick, PA
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I just found your VMix program and have been testing it out a bit. I currently have a competing Switcher program (VB) but am having all kinds of problems getting rid of video stuttering during capture and absolutely NO help from the creator. So far, with VMix I hardly see any stutter/frame drops at all. I am wondering if my system will be strong enough to handle VMix and 2 Sony FX-7 cameras connected by wire fire without creating a video stutter. I did see a few skips during tests, but they were pretty far apart, unlike the other brand. I am hoping with your help it can be explained how those hiccups can be avoided completely.
Here are the specs of my laptop:
Processor Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz Memory (RAM) 8.00 GB Graphics NVIDIA Quadro 3000M Gaming graphics 5866 MB Total available graphics memory Primary hard disk 329GB Free (465GB Total) Windows 7 Professional
System Manufacturer Dell Inc. Model Precision M6600 Total amount of system memory 8.00 GB RAM System type 64-bit operating system Number of processor cores 4
Storage Total size of hard disk(s)465 GB Disk partition (C 329 GB Free (465 GB Total) Media drive (D CD/DVD
Graphics Display adapter type NVIDIA Quadro 3000M Total available graphics memory 5866 MB Dedicated graphics memory 2048 MB Dedicated system memory 0 MB Shared system memory 3818 MB Display adapter driver version 8.17.12.6883 Primary monitor resolution 1600x900 DirectX version DirectX 10
Network Adapter Intel(R) 82579LM Gigabit Network Connection Network Adapter Teefer2 Miniport Network Adapter Intel(R) Centrino(R) Ultimate-N 6300 AGN Network Adapter
I have been assured by my I.T. guys this thing has plenty of power (but apparently not enough for VB). Anyway, I am seriously considering purchasing a license, but I need to make sure I get smooth, fluid, hiccup/Stutter Free video 98% of the time. With proper tweaking, in SD format using DV/Fire Wire outs from my camera's, is this possible... and if so, how so I can try it out for a few days before buying? Thanks... Oh, I manage a local origination channel for the local cable company and have close to 20 thousand viewers who will see the VMix logo on every production it is used with, if we can make this software hum with the equipment I already have.
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 756
Hi, another ex-vidblaster user... welcome. as a ex-vidblaster user i can tell you that vmix is working here about 1 year with 2 sony fx-7 firewire connected better than before. Your laptop setup seems to be good enought to run vmix without problems. By the way, Martin, the administrator, has been working with this excelent peace of software. He is working hard Every day on it and his support is realy wonderful. Hope you can be succeeded with vmix in your production. Regards, Melody www.espiritosanto.cc
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Hi Doug,
Based on the specifications provided, both SD and HD are possible on your hardware.
The only potential issue is how the firewire cameras are connected to the laptop. Firewire cameras require a dedicated port per camera, so are you using the inbuilt firewire port plus an expresscard adapter or some other configuration?
vMix comes with a 60 day trial to give you plenty of time to see if it works as expected.
Martin vMix
