Doug
#1 Posted : Wednesday, January 25, 2012 6:15:59 PM(UTC)
Doug
I just found your VMix program and have been testing it out a bit. I currently have a competing Switcher program (VB) but am having all kinds of problems getting rid of video stuttering during capture and absolutely NO help from the creator.
So far, with VMix I hardly see any stutter/frame drops at all.
I am wondering if my system will be strong enough to handle VMix and 2 Sony FX-7 cameras connected by wire fire without creating a video stutter. I did see a few skips during tests, but they were pretty far apart, unlike the other brand.
I am hoping with your help it can be explained how those hiccups can be avoided completely.
Here are the specs of my laptop:
Processor
Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz
Memory (RAM)
8.00 GB
Graphics
NVIDIA Quadro 3000M
Gaming graphics
5866 MB Total available graphics memory
Primary hard disk
329GB Free (465GB Total)
Windows 7 Professional
System Manufacturer Dell Inc.
Model Precision M6600
Total amount of system memory
8.00 GB RAM
System type
64-bit operating system
Number of processor cores 4
Storage
Total size of hard disk(s)465 GB
Disk partition (C 329 GB Free (465 GB Total)
Media drive (D CD/DVD
Graphics
Display adapter type NVIDIA Quadro 3000M
Total available graphics memory 5866 MB
Dedicated graphics memory 2048 MB
Dedicated system memory 0 MB
Shared system memory 3818 MB
Display adapter driver version 8.17.12.6883
Primary monitor resolution 1600x900
DirectX version DirectX 10
Network Adapter
Intel(R) 82579LM Gigabit Network Connection
Network Adapter
Teefer2 Miniport
Network Adapter
Intel(R) Centrino(R) Ultimate-N 6300 AGN
Network Adapter
I have been assured by my I.T. guys this thing has plenty of power (but apparently not enough for VB).
Anyway, I am seriously considering purchasing a license, but I need to make sure I get smooth, fluid, hiccup/Stutter Free video 98% of the time.
With proper tweaking, in SD format using DV/Fire Wire outs from my camera's, is this possible... and if so, how so I can try it out for a few days before buying?
Thanks... Oh, I manage a local origination channel for the local cable company and have close to 20 thousand viewers who will see the VMix logo on every production it is used with, if we can make this software hum with the equipment I already have.
melody
#2 Posted : Wednesday, January 25, 2012 8:11:59 PM(UTC)
Rank: Guest
Groups: Guests
Hi, another ex-vidblaster user... welcome.
as a ex-vidblaster user i can tell you that vmix is working here about 1 year with 2 sony fx-7 firewire connected better than before.
Your laptop setup seems to be good enought to run vmix without problems.
By the way, Martin, the administrator, has been working with this excelent peace
of software. He is working hard Every day on it and his support is realy wonderful.
Hope you can be succeeded with vmix in your production. Regards,
Melody
www.espiritosanto.cc
#3 Posted : Wednesday, January 25, 2012 10:57:46 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Hi Doug,
Based on the specifications provided, both SD and HD are possible on your hardware.
The only potential issue is how the firewire cameras are connected to the laptop. Firewire cameras require a dedicated port per camera, so are you using
the inbuilt firewire port plus an expresscard adapter or some other configuration?
vMix comes with a 60 day trial to give you plenty of time to see if it works as expected.
