Hardware Compatibility
Audio level indicator on magewell card xi400de-sdi wrong
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
I have a trouble with a magewell card xi 400de-sdi4 SDI inputs. Each embeded sdi audio channel input works, but level indicator is not working properly and the master is also false. For example on input 3 and 4 the right level is at top level all the time, and the level of left channel are at medium range even without signal. I have the last vmix, the last firmware of card and the last driver provided by magewell support. I have not the problem with decklink quad card.
Any ideas to solve problem ?
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi jmpaoli Just got mine XI400DE-SDI and also sorting out the audio. At the moment I import the audio as an input for each camera. Otherwise no audio in vMix but I guess early days. Any one else have a setup that they can share? Cheers Ash PS also getting incorrect level indicator jmpaoli wrote:I have a trouble with a magewell card xi 400de-sdi4 SDI inputs. Each embeded sdi audio channel input works, but level indicator is not working properly and the master is also false. For example on input 3 and 4 the right level is at top level all the time, and the level of left channel are at medium range even without signal. I have the last vmix, the last firmware of card and the last driver provided by magewell support. I have not the problem with decklink quad card.
It's not a vmix problem, i have the same audiolevel indicator issue in windows 7 sound control panel !
We investigate...
Hi Messaged support@magewell.net and received updated install. Fixed audio problem with levels indicator. Ash jmpaoli wrote:It's not a vmix problem, i have the same audiolevel indicator issue in windows 7 sound control panel !
We investigate...
Me too i received new driver but same problem :( what version you have ?
jmpaoli wrote:Me too i received new driver but same problem :( what version you have ?
Ash attached the following image(s):  SDI Card Audio Driver.png (20kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
You have a better support ! in two days late i received the .868 ! can you give me a link or send it to jeanmichel@novasud.com thanks
Hi This is the link I received for the update install. http://61.155.106.24/dow...XI400DE_SDI.20141024.rarHave also sent u copy of email with AMCAP.exe as attachment which I also received from Magewell support. Regards Ash jmpaoli wrote:You have a better support ! in two days late i received the .868 ! can you give me a link or send it to jeanmichel@novasud.com thanks
Many Thanks Ash, i test that monday morning
Best regards
Jean Michel
Ash, where did you end up sourcing the Magewell cards?
Hello Ask Directly from Magewell at sales@magewell.comask wrote:Ash, where did you end up sourcing the Magewell cards?
Thanks Ash,
Magewell card works well with this driver
Best regards
Jean Michel
Ash wrote:Hi This is the link I received for the update install. http://61.155.106.24/dow...XI400DE_SDI.20141024.rarHave also sent u copy of email with AMCAP.exe as attachment which I also received from Magewell support. Regards Ash jmpaoli wrote:You have a better support ! in two days late i received the .868 ! can you give me a link or send it to jeanmichel@novasud.com thanks Hi, Any chance I could get a copy of the AMCAP.exe please?
