jmpaoli
#1 Posted : 11 years ago
jmpaoli
I have a trouble with a magewell card xi 400de-sdi4 SDI inputs.
Each embeded sdi audio channel input works, but level indicator is not working properly and the master is also false.
For example on input 3 and 4 the right level is at top level all the time, and the level of left channel are at medium range even without signal.
I have the last vmix, the last firmware of card and the last driver provided by magewell support. I have not the problem with decklink quad card.
Any ideas to solve problem ?
Ash
#2 Posted : 11 years ago
Ash
You have been a member since:: 11/19/2013(UTC)
Was thanked: 11 time(s) in 8 post(s)
Hi jmpaoli
Just got mine XI400DE-SDI and also sorting out the audio.
At the moment I import the audio as an input for each camera. Otherwise no audio in vMix but I guess early days.
Any one else have a setup that they can share?
Cheers
Ash
PS also getting incorrect level indicator
jmpaoli
#3 Posted : 11 years ago
jmpaoli
It's not a vmix problem, i have the same audiolevel indicator issue in windows 7 sound control panel !
We investigate...
Ash
#4 Posted : 11 years ago
Ash
Hi
Messaged support@magewell.net and received updated install.
Fixed audio problem with levels indicator.
Ash
We investigate...
jmpaoli
#5 Posted : 11 years ago
jmpaoli
Me too i received new driver but same problem :( what version you have ?
Ash
#6 Posted : 11 years ago
Ash
Ash attached the following image(s):
SDI Card Audio Driver.png (20kb) downloaded 0 time(s).
jmpaoli
#7 Posted : 11 years ago
jmpaoli
You have a better support ! in two days late i received the .868 ! can you give me a link or send it to jeanmichel@novasud.com thanks
Ash
#8 Posted : 11 years ago
Ash
Hi
This is the link I received for the update install.
http://61.155.106.24/dow...XI400DE_SDI.20141024.rar
Have also sent u copy of email with AMCAP.exe as attachment which I also received from Magewell support.
Regards
Ash
jmpaoli
#9 Posted : 11 years ago
jmpaoli
Many Thanks Ash, i test that monday morning
Best regards
Jean Michel
ask
#10 Posted : 11 years ago
ask
Ash, where did you end up sourcing the Magewell cards?
Ash
#11 Posted : 11 years ago
Ash
Hello Ask
Directly from Magewell at sales@magewell.com
jmpaoli
#12 Posted : 11 years ago
jmpaoli
Thanks Ash,
Magewell card works well with this driver
Best regards
Jean Michel
pinkimp
#13 Posted : 10 years ago
pinkimp
Ash wrote:
Hi
Regards
Ash
Any chance I could get a copy of the AMCAP.exe please?
jmpaoli
#14 Posted : 10 years ago
jmpaoli
