Transition when Layer goes On/Off?
Joined: 9/5/2021(UTC) Posts: 7   Was thanked: 1 time(s) in 1 post(s)
Greetings, Is there a way to initiate a transition when a layer goes from on-to-off and off-to-on? I've got 4 monitor displays in a multi-view, and individual inputs for each display. On each of the individual displays I have a GT Title on Layer 3 with a label for a name, role, and another designator. The GT title transitions (TransitionIn and TransitionOut) work fine when Merging or Fading. I have a button on Companion set up with 4 actions, each one toggles Layer 3 on one of the displays. The GT Title goes on and off appropriately when the button is pressed... except no transition - a straight cut to on or off. Is there a way to set a transition that plays when toggling a layer on/off while the input is already on a Multiview in Program? Thanks for any suggestions... I know this isn't "end of the world" stuff if these have to cut in/out instead of fade.
Joined: 12/27/2012(UTC) Posts: 5,475  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Use triggers on the overlay input (onoverlayIn/Out)
Joined: 9/22/2020(UTC) Posts: 44  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Another way is to use custom command in companion you can have it start a couple miliseconds after you trigger the layer
vmix: Scripting - Run custom command : TitleBeginAnimation Value=TransitionIn&Input=Title
vmix: Scripting - Run custom command : TitleBeginAnimation Value=TransitionOut&Input=Title
