OldDesertLizard
#1 Posted : Sunday, November 20, 2022 3:24:22 AM(UTC)
OldDesertLizard
Greetings,
Is there a way to initiate a transition when a layer goes from on-to-off and off-to-on?
I've got 4 monitor displays in a multi-view, and individual inputs for each display. On each of the individual displays I have a GT Title on Layer 3 with a label for a name, role, and another designator. The GT title transitions (TransitionIn and TransitionOut) work fine when Merging or Fading.
I have a button on Companion set up with 4 actions, each one toggles Layer 3 on one of the displays. The GT Title goes on and off appropriately when the button is pressed... except no transition - a straight cut to on or off.
Is there a way to set a transition that plays when toggling a layer on/off while the input is already on a Multiview in Program?
Thanks for any suggestions... I know this isn't "end of the world" stuff if these have to cut in/out instead of fade.
One-Up Display with "Identifier Bar" at the bottom
4-up display - I'd like the "identifier bars" to transition when the layers are turned on/off
#2 Posted : Sunday, November 20, 2022 4:30:27 AM(UTC)
Use triggers on the overlay input (onoverlayIn/Out)
Howlswolf
#3 Posted : Tuesday, November 22, 2022 3:37:45 AM(UTC)
Howlswolf
Canada
Another way is to use custom command in companion you can have it start a couple miliseconds after you trigger the layer
vmix: Scripting - Run custom command : TitleBeginAnimation Value=TransitionIn&Input=Title
vmix: Scripting - Run custom command : TitleBeginAnimation Value=TransitionOut&Input=Title
