Clint Cruz
#1 Posted : Tuesday, October 18, 2022 3:38:13 PM(UTC)
Clint Cruz
Hi, When i first start a new preset, i can either drag or input into the VMIX and the Filename would be used as its Input Name. (ie open the cog wheel for settings and in general the name would follow the File Name.)
i have a preset that i have been working with for a long time. it has many triggers and shortcuts, ptz camera control settings, that i dont want to start from the beginning putting a new preset. What has been happening with this preset is, I would change the Input (which is a Video) to an existing Input. and when i do this... it doesnt carry over the input name (File Name) i would have to cut and paste to rename the input.
Is there a way to make it default again and have the input name follow the input video file name? if so please share how to do this.
thanks in advance.
dmwkr
#2 Posted : Wednesday, October 19, 2022 12:42:03 AM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
You probably edited the name in the input settings somewhen. Open the input settings, erase the tex in the 'Name' field, close the settings. When you change the file it should now show the corresponding file name again.
Similar Topics
Add input names to the "Fullscreen" button drop-down (Feature Requests)
by WaltG12 2/19/2023 1:32:04 PM(UTC)
Input Names on External Output Selector (Feature Requests)
by lampywithacamera 10/25/2022 10:26:31 PM(UTC)
Newest vMix update does not allow me to leave 'List' input names blank (General Discussion)
by trufflepig 5/25/2022 9:58:44 AM(UTC)
Input Position Input Names (Feature Requests)
by Thomas12 3/18/2022 8:39:19 PM(UTC)
Input names instead of numbers at fullscreen and external output dropdowns (Feature Requests)
by CyberNBD 9/14/2020 3:05:05 AM(UTC)
Minor Bug: Ampersands in input names (General Discussion)
by TBacker 12/22/2019 8:09:12 AM(UTC)
Show Input names in the Position selection dropdown (Feature Requests)
by richardgatarski 10/25/2018 4:50:33 AM(UTC)
Use operator defined Input names for NDI Outputs (Feature Requests)
by richardgatarski 4/19/2016 5:41:14 AM(UTC)
Input names vs. Input1, 2, etc... (Feature Requests)
by lbgaus 9/4/2014 3:09:17 PM(UTC)
Multiview input names (Feature Requests)
by HighViewSport 7/11/2014 4:37:32 AM(UTC)
renaming capture input names (General Discussion)
by h2video.nl 11/19/2013 8:58:31 AM(UTC)
