Joined: 4/24/2020(UTC) Posts: 13  Location: Garden Grove Thanks: 3 times
Hi, When i first start a new preset, i can either drag or input into the VMIX and the Filename would be used as its Input Name. (ie open the cog wheel for settings and in general the name would follow the File Name.)
i have a preset that i have been working with for a long time. it has many triggers and shortcuts, ptz camera control settings, that i dont want to start from the beginning putting a new preset. What has been happening with this preset is, I would change the Input (which is a Video) to an existing Input. and when i do this... it doesnt carry over the input name (File Name) i would have to cut and paste to rename the input.
Is there a way to make it default again and have the input name follow the input video file name? if so please share how to do this.
thanks in advance.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
You probably edited the name in the input settings somewhen. Open the input settings, erase the tex in the 'Name' field, close the settings. When you change the file it should now show the corresponding file name again.
