FabioLibardi
#1 Posted : Saturday, October 8, 2022 1:54:56 AM(UTC)
FabioLibardi
Italy
Very often I use the fullscreen 2 or the external output to manage a ledwall or a video projector. This allows me to manage on-screen content other than what I stream or record.
Currently I do it without any problem, but I am always forced to use a "cut". It would be very nice to be able to use a fade as well, but it seems that the software does not allow this.
Could you be interested in implementing it?
#2 Posted : Saturday, October 8, 2022 2:10:39 AM(UTC)
Maybe change the Alpha of an input used over time (script) to 0
Using a Mix input can also be usefull
landerdahl
#3 Posted : Tuesday, October 11, 2022 7:00:45 AM(UTC)
landerdahl
Sweden
There is a method for this. Use the Mix Input and set that as Fullscreen2 source. Now you can use fade as a transition. If you want to read some more about the Mix input, look here: https://www.vmix.com/help25/Mix.html
I use this in similar use case as you describe. I made a shortcut to my Stream Deck so that i can select what goes to the mix2 preview, and one button to use the fade transition in Mix2
Hope that helps!
