Fade on Fullscreen/External
Very often I use the fullscreen 2 or the external output to manage a ledwall or a video projector. This allows me to manage on-screen content other than what I stream or record.
Currently I do it without any problem, but I am always forced to use a "cut". It would be very nice to be able to use a fade as well, but it seems that the software does not allow this.
Could you be interested in implementing it?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: FabioLibardi  Very often I use the fullscreen 2 or the external output to manage a ledwall or a video projector. This allows me to manage on-screen content other than what I stream or record.
Could you be interested in implementing it? Maybe change the Alpha of an input used over time (script) to 0 Using a Mix input can also be usefull
Joined: 12/6/2020(UTC) Posts: 6  Location: Visby Thanks: 1 times
Could you be interested in implementing it? There is a method for this. Use the Mix Input and set that as Fullscreen2 source. Now you can use fade as a transition. If you want to read some more about the Mix input, look here: https://www.vmix.com/help25/Mix.htmlI use this in similar use case as you describe. I made a shortcut to my Stream Deck so that i can select what goes to the mix2 preview, and one button to use the fade transition in Mix2 Hope that helps!
