Falcon91
#1 Posted : Thursday, June 16, 2022 11:17:16 PM(UTC)
Falcon91
Canada
Hello folks, this is my first time streaming with Vmix and am getting this error while trying to stream to Youtube and facebook live, your help is needed,Thanks
FFMPEG1.Exited
Streaming
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
rtmp://a.rtmp.youtube.com/live2/359e-a8wy-rr83-57j3-7fbq1: Input/output error
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 6803.709000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 50 tbr, 10000k tbn, 50 tbc
[tcp @ 04d3ad20] TCP Buffer has been set to 13140992 bytes
[dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (62% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped!
#2 Posted : Friday, June 17, 2022 8:07:48 PM(UTC)
@ Falcon91
Getting an Input/Output error at the start of a stream attempt is usually an indication that the streaming provider is either not getting your feed due to something on your system or network blocking it (antivirus software for example) or the streaming provider is rejecting your stream feed for some reason (commonly invalid credentials or permissions).
