Hello Folks i am getting this error (FFMPEG1.Exited error)
Hello folks, this is my first time streaming with Vmix and am getting this error while trying to stream to Youtube and facebook live, your help is needed,Thanks
FFMPEG1.Exited Streaming Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s rtmp://a.rtmp.youtube.com/live2/359e-a8wy-rr83-57j3-7fbq1: Input/output error
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 6803.709000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 50 tbr, 10000k tbn, 50 tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [tcp @ 04d3ad20] TCP Buffer has been set to 13140992 bytes [dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (62% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02329320] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped! rtmp://a.rtmp.youtube.com/live2/359e-a8wy-rr83-57j3-7fbq1: Input/output error
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Falcon91
Getting an Input/Output error at the start of a stream attempt is usually an indication that the streaming provider is either not getting your feed due to something on your system or network blocking it (antivirus software for example) or the streaming provider is rejecting your stream feed for some reason (commonly invalid credentials or permissions).
