Coffeedrunk
#1 Posted : Wednesday, October 8, 2014 12:36:21 AM(UTC)
Coffeedrunk
Just wondering if anyone out there ever given it a go before? I've pasted the new i5 specs below. Finding a suitable capture card looks to be a concern. If anyone has had any experience be get to hear for you.
4th Generation Intel Core i5-4250U processor
Intel HD Graphics 5000
Dual channel SODIMM DDR3L 1333/1600 MHz, 1.35V
Internal support for 2.5" HDD or SSD
Intel Turbo Boost Technology 2.0
4 USB3.0 Ports
Compatible with Linux (Linux Mint, Fedora, Ubuntu, OpenSUSE) and Windows 7
Headphone/Microphone Jack
Supports Mobile SATA (SSD) card via full-length PCIe Mini Card
r@wisla
#2 Posted : Wednesday, October 8, 2014 11:52:08 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Intel NUC should also have a thunderbolt port. If it's your case use Blackmagic UltraStudio Mini Recorder.
Coffeedrunk
#3 Posted : Thursday, October 9, 2014 1:51:19 AM(UTC)
Coffeedrunk
They discontinued thunder bolt on the latest version. It only has a mini DisplayPort unfortunately. It does have 4 USB3 ports but I don't know of any USB3 video cards that take multi SDI inputs. I normally need a minimum of 2 inputs I was thinking about getting 2 of the XI100DUSB-SDI dongles but at $300.00 each the price for the complete unit starts getting up there.
Jackster
#4 Posted : Thursday, October 9, 2014 9:44:49 AM(UTC)
Jackster
The CPUs in these are very under powered due to the heat problem.
Best to go for a small HTPC or 1U form factor if you want small. Means you get PCIe easily to..
doyousee.me
#5 Posted: : Saturday, October 11, 2014 1:03:33 PM(UTC)
doyousee.me
you'll probly miss some gpu power as well, making it a less than ideal box for mixing video
M@ik
(a huge NUC fan, so i'll probably give one a try anyway, but only have i3's on stock for my signage solutions)
