Hardware Compatibility
Intel NUC / Mini streaming rigs
Just wondering if anyone out there ever given it a go before? I've pasted the new i5 specs below. Finding a suitable capture card looks to be a concern. If anyone has had any experience be get to hear for you.
4th Generation Intel Core i5-4250U processor Intel HD Graphics 5000 Dual channel SODIMM DDR3L 1333/1600 MHz, 1.35V Internal support for 2.5" HDD or SSD Intel Turbo Boost Technology 2.0 4 USB3.0 Ports Compatible with Linux (Linux Mint, Fedora, Ubuntu, OpenSUSE) and Windows 7 Headphone/Microphone Jack Supports Mobile SATA (SSD) card via full-length PCIe Mini Card
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Intel NUC should also have a thunderbolt port. If it's your case use Blackmagic UltraStudio Mini Recorder.
They discontinued thunder bolt on the latest version. It only has a mini DisplayPort unfortunately. It does have 4 USB3 ports but I don't know of any USB3 video cards that take multi SDI inputs. I normally need a minimum of 2 inputs I was thinking about getting 2 of the XI100DUSB-SDI dongles but at $300.00 each the price for the complete unit starts getting up there.
Joined: 8/1/2013(UTC) Posts: 32  Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
The CPUs in these are very under powered due to the heat problem. Best to go for a small HTPC or 1U form factor if you want small. Means you get PCIe easily to..
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
you'll probly miss some gpu power as well, making it a less than ideal box for mixing video
M@ik (a huge NUC fan, so i'll probably give one a try anyway, but only have i3's on stock for my signage solutions)
