jkhouw
#1 Posted : Wednesday, February 16, 2022 11:01:53 PM(UTC)
jkhouw
If you animate something in GT Title Editor setting the storyboard animation type to "Continuous" it loops the animation infinitely.
I would like the ability to insert a delay between the loops. With an image sequence its possible to backdoor your way into a delay by adding blank or repeating images - but for longer delays this is not optimal at all, and does not allow easy control. With a FillOffset, RotateContinous or StrokeOffset there is no way I could find as a workaround.
Since there already exists a toolbar area for "Timing", and the Storyboard already has a field called "Delay" which is used by other transition types (in/out e.g.) it should be trivial to add this.
You could even use the "Style" attribute/field to flag if the delay should be "pre" or "post" animation.
#2 Posted : Thursday, February 17, 2022 1:04:18 AM(UTC)
Continuous : forming an unbroken whole; without interruption. ;-)
jkhouw
#3 Posted : Thursday, February 17, 2022 1:15:52 AM(UTC)
jkhouw
Then change the request to add "Repeat", copying the exact functionality of "Continuous" but adding the ability to inject a delay between repeated cycles. That however is semantics and would seem to require more development work.
