Feature Requests
GT Title Editor: ability to delay continuous animations
If you animate something in GT Title Editor setting the storyboard animation type to "Continuous" it loops the animation infinitely. I would like the ability to insert a delay between the loops. With an image sequence its possible to backdoor your way into a delay by adding blank or repeating images - but for longer delays this is not optimal at all, and does not allow easy control. With a FillOffset, RotateContinous or StrokeOffset there is no way I could find as a workaround. Since there already exists a toolbar area for "Timing", and the Storyboard already has a field called "Delay" which is used by other transition types (in/out e.g.) it should be trivial to add this. You could even use the "Style" attribute/field to flag if the delay should be "pre" or "post" animation.  FeatureRequest.png (43kb) downloaded 4 time(s).
Continuous : forming an unbroken whole; without interruption. ;-)
Originally Posted by: doggy  Continuous : forming an unbroken whole; without interruption. ;-) Then change the request to add "Repeat", copying the exact functionality of "Continuous" but adding the ability to inject a delay between repeated cycles. That however is semantics and would seem to require more development work.
Feature Requests
