Hi all,
I would like to ask, did anyone tried to put in this Sonnet SE IIIe enclosure 2 Decklink Duo 2 cards nad one Blackmagic Design Mini Monitor 4K card. My goal is to have 8in 1out configuration on laptop. Would be there any bottlenecks in this configuration?
Joined: 10/20/2023(UTC) Posts: 163  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: Zorangr  Hi all,
I would like to ask, did anyone tried to put in this Sonnet SE IIIe enclosure 2 Decklink Duo 2 cards nad one Blackmagic Design Mini Monitor 4K card. My goal is to have 8in 1out configuration on laptop. Would be there any bottlenecks in this configuration? Even though the question is old,
The Sonnet Echo Express SE IIIe enclosure is equipped with the Intel JHL6540 Thunderbolt 3 controller.
Intel JHL6540 = PCIe 3.0 x4 = 32 Gbps Therefore, after deducting the encoding payload, the actual PCIe tunnel throughput = approximately 22 Gbps = 2.75 GB/s To have the full data bandwidth, you should not connect a display to the enclosure. (= Data Only)
The JHL6540 Thunderbolt controller is full duplex, so it has:
2 x 20 Gbps upstream = 2.75 GB/s 2 x 20 Gbps downstream = 2.75 GB/s That is, 2.75 GB/s in both directions simultaneously.
Behind the Intel JHL6540 controller, there is a PEX 8724 chip which handles traffic management for the 3 PCIe slots
The PEX 8724 chip supports 24 lanes Gen 3.0 :
3.0 x4 = Thunderbolt 3 interface card 3.0 x8 = PCIe slot 1 3.0 x8 = PCIe slot 2 3.0 x4 = PCIe slot 3
It is the PEX 8724 chip that makes it possible to connect PCIe x8 cards
Therefore, if PEX 8724 = PCIe 3.0 x24 = 24 GB/s It is the Thunderbolt controller that determines the limits, as the Intel JHL6540 = 2.75 GB/s full duplex
So, the most important thing is to verify that the data throughput of all the I/O on the PCIe cards does not exceed the maximum capacity of the Thunderbolt connection.
For Full HD productions, I use a Sonnet Echo Express SE IIIe + 2 Magewell Pro Quad HDMI for 8 x 1080p50 YUY2 inputs + 1 Decklink Duo 2 for 4 x 1080p50 YUY2 external outputs
1080p50 YUY2 = 208 MB/s Therefore : upstream = 8 inputs = 8 x 208 = 1.66 GB/s (less than 2.75 GB/s) = OK downstream = 4 outputs = 4 x 208 = 832 MB/s (less than 2.75 GB/s) = OK
Everything works perfectly. Therefore, 2 x Decklink Duo 2 + 1 x Decklink Mini Monitor 4K should not be a problem.
One last point: For these configurations, it is best to use systems with Thunderbolt ports are directly connected to CPU.
Laptop: Tiger Lake-H / Alder Lake-H / Raptor Lake-H / Meteor Lake-H / Arrow Lake-H and HX Desktop: Arrow Lake-S / AM5 (with ASM4242)Edit : In theory, to use the Sonnet Echo Express SE IIIe to its full potential, you would need to install 3 x Decklink 8K Pro for: 6 x 4K25p YUY2 inputs = (415 x 6 = 2.49 GB/s TX) or (5 x 4K30p YUY2) + 6 x 4K25p YUY2 outputs = (415 x 6 = 2.49 GB/s RX) or (5 x 4K30p YUY2) If anyone has already tested this, your feedback would be appreciated.
