2 Pages<12
Zorangr
#21 Posted : Monday, February 26, 2024 6:18:28 PM(UTC)
Zorangr
Montenegro
Hi all,
I would like to ask, did anyone tried to put in this Sonnet SE IIIe enclosure 2 Decklink Duo 2 cards nad one Blackmagic Design Mini Monitor 4K card. My goal is to have 8in 1out configuration on laptop. Would be there any bottlenecks in this configuration?
Kayo33
#22 Posted : Thursday, November 5, 2026 7:34:15 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: Zorangr Go to Quoted Post
Hi all,
Even though the question is old,
The Sonnet Echo Express SE IIIe enclosure is equipped with the Intel JHL6540 Thunderbolt 3 controller.
Intel JHL6540 = PCIe 3.0 x4 = 32 Gbps
Therefore, after deducting the encoding payload, the actual PCIe tunnel throughput = approximately 22 Gbps = 2.75 GB/s
To have the full data bandwidth, you should not connect a display to the enclosure. (= Data Only)
The JHL6540 Thunderbolt controller is full duplex, so it has:
2 x 20 Gbps upstream = 2.75 GB/s
2 x 20 Gbps downstream = 2.75 GB/s
That is, 2.75 GB/s in both directions simultaneously.
Behind the Intel JHL6540 controller, there is a PEX 8724 chip which handles traffic management for the 3 PCIe slots
The PEX 8724 chip supports 24 lanes Gen 3.0 :
3.0 x4 = Thunderbolt 3 interface card
3.0 x8 = PCIe slot 1
3.0 x8 = PCIe slot 2
3.0 x4 = PCIe slot 3
It is the PEX 8724 chip that makes it possible to connect PCIe x8 cards
Therefore, if PEX 8724 = PCIe 3.0 x24 = 24 GB/s
It is the Thunderbolt controller that determines the limits, as the Intel JHL6540 = 2.75 GB/s full duplex
So, the most important thing is to verify that the data throughput of all the I/O on the PCIe cards does not exceed the maximum capacity of the Thunderbolt connection.
For Full HD productions, I use a Sonnet Echo Express SE IIIe
+ 2 Magewell Pro Quad HDMI for 8 x 1080p50 YUY2 inputs
+ 1 Decklink Duo 2 for 4 x 1080p50 YUY2 external outputs
1080p50 YUY2 = 208 MB/s
Therefore :
upstream = 8 inputs = 8 x 208 = 1.66 GB/s (less than 2.75 GB/s) = OK
downstream = 4 outputs = 4 x 208 = 832 MB/s (less than 2.75 GB/s) = OK
Everything works perfectly.
Therefore, 2 x Decklink Duo 2 + 1 x Decklink Mini Monitor 4K should not be a problem.
One last point:
For these configurations, it is best to use systems with Thunderbolt ports are directly connected to CPU.
Laptop: Tiger Lake-H / Alder Lake-H / Raptor Lake-H / Meteor Lake-H / Arrow Lake-H and HX
Desktop: Arrow Lake-S / AM5 (with ASM4242)
Edit :
In theory, to use the Sonnet Echo Express SE IIIe to its full potential, you would need to install 3 x Decklink 8K Pro for:
6 x 4K25p YUY2 inputs = (415 x 6 = 2.49 GB/s TX) or (5 x 4K30p YUY2)
+ 6 x 4K25p YUY2 outputs = (415 x 6 = 2.49 GB/s RX) or (5 x 4K30p YUY2)
If anyone has already tested this, your feedback would be appreciated.
2 Pages<12
