jpeg2RAW
#1 Posted : Sunday, September 14, 2014 9:40:53 PM(UTC)
jpeg2RAW
I just made a lower 3rd the way I want it, position and size wise. Now I would like to copy that input to make another lower 3rd for my co-host. Can you copy an input like this?
curtismacd31
#2 Posted : Monday, September 15, 2014 10:28:52 AM(UTC)
curtismacd31
Why don't you just add a quick template change?
jpeg2RAW
#3 Posted : Monday, September 15, 2014 10:58:59 AM(UTC)
jpeg2RAW
How do you do a quick template change? I looked around and checked the documentation, but I can't find anything on "quick template change".
curtismacd31
#4 Posted : Tuesday, September 16, 2014 12:27:43 PM(UTC)
curtismacd31
in the template editor you can change the template feilds, then hit the big plus and it will save it as a template (image 1)
once you have all the templates made (image 2) you can then close the title editor and right click on the title input and you will see the text you just added as templates. (image 3)
Hope this helps.
rtinfow
#5 Posted : Sunday, March 1, 2015 9:20:51 AM(UTC)
rtinfow
My natural way of working is similar. I build the most complex composite from multiple sources, then copy and remove pieces until I get to the starting point. That way I know a build is in registration. Also looking for an alternative.
Guest (4)
Similar Topics
COPY INPUTS (General Discussion)
by mitchstein443 7/16/2024 12:01:29 PM(UTC)
Copy Input Camera Color Settings (Feature Requests)
by bluesman64 11/17/2018 1:04:56 AM(UTC)
Ability To Copy Inputs From One Preset To Another (Feature Requests)
by JimJacobs 2/12/2017 11:56:49 AM(UTC)
