I just made a lower 3rd the way I want it, position and size wise. Now I would like to copy that input to make another lower 3rd for my co-host. Can you copy an input like this?
jpeg2RAW wrote:I just made a lower 3rd the way I want it, position and size wise. Now I would like to copy that input to make another lower 3rd for my co-host. Can you copy an input like this? Why don't you just add a quick template change?
How do you do a quick template change? I looked around and checked the documentation, but I can't find anything on "quick template change".
jpeg2RAW wrote:How do you do a quick template change? I looked around and checked the documentation, but I can't find anything on "quick template change". in the template editor you can change the template feilds, then hit the big plus and it will save it as a template ( image 1) once you have all the templates made ( image 2) you can then close the title editor and right click on the title input and you will see the text you just added as templates. ( image 3) Hope this helps.
Joined: 3/1/2015(UTC) Posts: 1 Location: Rockaway, NJ USA
jpeg2RAW wrote:I just made a lower 3rd the way I want it, position and size wise. Now I would like to copy that input to make another lower 3rd for my co-host. Can you copy an input like this? My natural way of working is similar. I build the most complex composite from multiple sources, then copy and remove pieces until I get to the starting point. That way I know a build is in registration. Also looking for an alternative.
