GT
Title transition IN/OUT via API
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
I need to do something I thought would be simple with the API. I need to select an input and send "transition in" and "transition out" Just like right clicking in the window. I cannot find anywhere to do this in the API. Am I missing something?
Steve
TitleBeginAnimation - the title - value: TransitionOut or TransitionIn
 2 users thanked doggy for this useful post.
OK that is slightly obscure. Thanks, I will try it now.
It would be nice if the each of the API commands had a sample in the help. It would cut down on a lot of this.
Thanks again, Steve
Update
Works great ! http://localhost:8088/api/?function=TitleBeginAnimation&Input=Graphic1&Value=TransitionIN http://localhost:8088/api/?function=TitleBeginAnimation&Input=Graphic1&Value=TransitionOUT
 1 user thanked stevespaw for this useful post.
Originally Posted by: stevespaw  OK that is slightly obscure. Thanks, I will try it now.
Agree,, or a little more explanations like what might the value asked need to be ? once you check aha TitleBeginAnimation (in the title section) .... title ok makes sense , Value ???? number ...nope.. what if same as animation options in title designer, worded the same as in the right click ... BINGO! ;-) oh can do the other animations designed in the title too... ok all makes sense now Indeed would have been quicker if a little help would say Value: any animation designed/used within the title or something
GT
