stevespaw
#1 Posted : Wednesday, September 1, 2021 3:56:11 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I need to do something I thought would be simple with the API.
I need to select an input and send "transition in" and "transition out"
Just like right clicking in the window. I cannot find anywhere to do this in the API.
Am I missing something?
Steve
#2 Posted : Wednesday, September 1, 2021 4:26:04 AM(UTC)
TitleBeginAnimation - the title - value: TransitionOut or TransitionIn
thanks 2 users thanked doggy for this useful post.
stevespaw on 9/1/2021(UTC), stigaard on 9/1/2021(UTC)
stevespaw
#3 Posted : Wednesday, September 1, 2021 4:44:39 AM(UTC)
stevespaw
OK that is slightly obscure.
Thanks, I will try it now.
It would be nice if the each of the API commands had a sample in the help. It would cut down on a lot of this.
Thanks again,
Steve
Update
Works great !
http://localhost:8088/api/?function=TitleBeginAnimation&Input=Graphic1&Value=TransitionIN
http://localhost:8088/api/?function=TitleBeginAnimation&Input=Graphic1&Value=TransitionOUT
thanks 1 user thanked stevespaw for this useful post.
#4 Posted : Wednesday, September 1, 2021 5:04:44 AM(UTC)
Agree,, or a little more explanations like what might the value asked need to be ?
once you check aha TitleBeginAnimation (in the title section) .... title ok makes sense , Value ???? number ...nope.. what if same as animation options in title designer, worded the same as in the right click ... BINGO! ;-)
oh can do the other animations designed in the title too... ok all makes sense now
Indeed would have been quicker if a little help would say Value: any animation designed/used within the title or something
