coskel22
#1 Posted : Wednesday, September 10, 2014 8:38:06 AM(UTC)
coskel22
Or what is the best way to do captions in vmix live?
I have an upcoming event that will be captioned in another language.
Event is live.
Captions will be sent from a powerpoint, and split between a screen onsite above stage and then another output on vga to me.
I was thinking desktop capture, but I would need to crop it so only the small strip of text shows unless there is a way to "alpha channel" on an input?
Running the captions manually is NOT an option - I have to take their output as it is synched to stage action.
richardgatarski
#2 Posted : Wednesday, September 10, 2014 8:47:51 AM(UTC)
richardgatarski
When is the event?
We are working on adapting an existing hw based technology for that into vMix.
It sort of works already, but a few additional needs (like recording the captions) will be adressed.
Check out the demo in another topic (second post).
richardgatarski
#3 Posted : Wednesday, May 20, 2015 6:48:02 AM(UTC)
richardgatarski
